10-20-2010 08:52 PM - edited 03-21-2019 03:09 AM
Dear Everyone,
I need help to troubleshoot logout from hunt group. One of my users keep logout from hunt group for unknown reason. Is there a way to prevent user logout from hunt group and join the extension back to hunt group.
Please help.
Lum
10-21-2010 05:06 AM
The only way to prevent logging off of a hunt group is to disable the HLOG softkey in the ephone-template. However, this is not configurable in CCA.
Adam Compton
10-21-2010 09:32 AM
If its a BACD member, and it misses calls, it will auto logout if you configured it that way in CCA.
10-21-2010 09:03 PM
Hi Steven,
In my UC520 I didnt setup call handing. It perform basic hunt feature. Hunt logout only happend for this extension. Could you advice me where i can login the hunt group?
Lum
02-24-2012 02:37 AM
Did you manage to solve this issue? When a user logout it keeps on saying logout on the screen and does not log back in.
any suggestions?
Thanks.
02-24-2012 11:50 PM
HLog key allows them to logged back in
If you want to remove the ability to log out of hunt group then remove softkey from ephone-template, now available in CCA
If BACd, disable option to logout after X amount of missed calls
03-02-2012 02:09 AM
Thanks a lot Mario. How stupid of me that I didn't know HLog is for login and logout.
Thanks again.
