2.3 new feature, old problem
I was hoping that two of the most anoying "features" are solved with the new firmware 2.3.1 (14). But they don't work for me:
1) "Return Call without edit dial"
I still have to add a leading "0" to the number to call someone back.
2) Enhanced Caller ID Directory mapping.
I added some numbers to the external directory. But in the display only the number is shown. In the directory I tried numbers with none, one and two leading zeros (151xxx, 0151xxx and 00151xxx) as well in the international format (+49151xxx, its in Germany).
Any hints for that?
My UC320 is working with a Mediatrix 4402 on an ISDN-line.
Karsten
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Matthew Needs
Hi Karsten,
Check this out.. We've had similar issues before. I think your issue could be more to do with the Mediatrix config rather than the UC's features not working correctly?.
Good luck. Please rate all useful posts.
https://supportforums.cisco.com/message/3502982#3502982
Matt
Thanks, first problem solved. I assumed it to be aan UC320-problem as many people were talking about that.
Glad to help.. Also, Someone has posted a similar issue to your second question here. It may help you?
https://supportforums.cisco.com/message/3704635#3704635
Cheers
Matt
Sadly that doesn't seem to be the problem with the directory.
