Community Member
504g issue with GPick
hi guys,
Having a strange oneway audio problem with 504g phones hosted on broadworks. Phones are running 7.4.9c software. We deploy two types of codec priorities for different scenarios.
Phone 1:
<Preferred_Codec_1_ ua="na">G729a</Preferred_Codec_1_>
  <Use_Pref_Codec_Only_1_ ua="na">No</Use_Pref_Codec_Only_1_>
  <Second_Preferred_Codec_1_ ua="na">G722</Second_Preferred_Codec_1_>
  <Third_Preferred_Codec_1_ ua="na">G711a</Third_Preferred_Codec_1_>
Phone 2:
<Preferred_Codec_1_ ua="na">G722</Preferred_Codec_1_>
  <Second_Preferred_Codec_1_ ua="na">G729a</Second_Preferred_Codec_1_>
When phone 1 dials into the system and phone2 picks up the call through grouppickup (by dialing *98 for example), phone 1 is not able to hear anything but there is audio on phone 2. Looking at the sip trace when phone 2 dial in (with g722 priority) server OKs the call with g722. And the reinvite sent back to phone1 to connect the audio has sdp ( payload 9 8 18) and phone1 OK the call with g729 where the other side of the call was g722.
phone1 invite (payload 18 9 8) --> broadworks
phone 1 <-- 200OK from broadworks (payload 18)
phone2 invite (payload 9 8 18) --> broadworks (group pick dialing *98)
phone 2 <-- 200OK from broadworks (payload  9)
phone1 <-- reinvite from broadworks ( 9 8 18)
phone1 200 OK (payload 18) --> broadworks
phone2 can hear, but phone 1 has no audio since it is negotiated g729 but not g722 even if the reinvite has priority 9.
I'm wondering why phone2 sends 200 OK with 18 and not 9 when it received reINVITE for 9. Other phone (polycoms and aastras) works fine as it 200 OKs the call with payload 9 after the reinvite from broadworks. I dont want to use  Use_Pref_Codec_Only.
Any thoughts?
thanks
Rakesh
1 ACCEPTED SOLUTION
Community Member
I will bet that you have the following parameter on your configuration file:
Yes
Set the parameter to:
No
and retry the test. I already have passed through a similar situation.
Joao
Community Member
Yes
No
Joao
Community Member
Hi Joao
Thanks for your help! Looks like that fixed it! :-)
cheers
Rakesh
775
