Community Member
524G Says Initializing Network
The 524G never says anything else but initializing network.  I am not sure if it ever worked.  It is connected to a UC500.  I tried entering the phone in the CCA but that did not make a difference.
Re: 524G Says Initializing Network
The initializing message is displayed by the phone while it performs a DHCP DISCOVER and is waiting for a DHCP OFFER from a DHCP server.
Verify that the UC500 has a DHCP server available on the network port that the phone is connected to.
Patrick
Could it be that your DHCP server does not have an available IP addresses for this phone?
Try factory resetting the phone.
Patrick
Community Member
The phone is connected directly to the UC500.  There are 5 or 6 other phones connected that are working.  If I plug another 524G to that same cable, that 524G works.
Thanks for the response.
Community Member
How do you factory reset the phone?
Factory reset as follows:
  1. Setup button [looks like an open book]
  2. 7 [Factory Reset]
  3. Select soft button
  4. OK soft button
Patrick
Community Member
No luck after factory default.   Still same message.   Is there any way to get different software to the phone?  It has 8.1.7.  I have 8.1.13 I could put on there.
Community Member
Even on the software it has, it should be possible for the phone to get an IP. Could you collect the following:
- debug ip dhcp server events
while you reset the phone?
Marcos
Community Member
I will collect the debug next time I am in the office.
Interestingly enough, when I changed the phone from DHCP to a static IP, I had the same problem.  It never makes it past initializing network.
Community Member
I am having the same problem with a 521 S. i just uploaded my case onto the following link:
https://www.myciscocommunity.com/message/42362#42362
I don't want to replicate my case on this post also, to avoid spamming. But i would really appreciate a response from you.
Thanks..
3878
