Community Member
AA Call forwarding by country
Hi all,
I'm trying to configure call forwarding based on the country where the call originated by AA.
I am using CUCM 7.1 and the CUE Editor 7.0.6.
Anyone have any idea how to do it?
thaks in advanced.
Everyone's tags (6)
Community Member
Hi Antonio,
I suspect that this would require a custom AA script to achieve this, Paolo one of the regular contributors on these forums has in the past been very helpful with custom scripts.
I'll Try and send on a message to Paolo unless he sees this post before I message him
Cheers,
David Trad.
davidtradconsultinggmail.com
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Community Member
Re: AA Call forwarding by country
Hi David,
You're right. I need a custom AA to do it.
Thank you for your answer and I'll wait for Paolo post.
Best Regards,
Antonio Santos
387
