AA prompt
I just change my UC520 lamguage to french, but french prompt like BusinessOpen.wav, BusinessClosed.wav are not available. Where can I download them ?
1 ACCEPTED SOLUTION
Re: AA prompt
Do you mean you are still hearing the English prompts after localizing to French?
Marcos
Re: AA prompt
Marcos
Re: AA prompt
no nothing. I suppose to copy them before localizing. I have any prompt in the system now.
Re: AA prompt
OK, I think you mean that you don't hear anything??
Did you follow this procedure:
https://supportforums.cisco.com/docs/DOC-9692
The above is for CCA 1.9, but the steps should be similar if you are using 2.0.
Marcos
Re: AA prompt
I followed this document, but didn't do step 2, that why I lost the prompt (AABusinessOpen.wav, AABusinessClosed.wav......)
2500
