Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Added a RV220W in front of my UC540
We switched internet provider to get a 120mbits/20mbits internet connection.  The UC540 is not able to handle more than 30mbits of data on the WAN port.  So I was told to add RV220W in front of the UC540.  I have disable the WAN port on te 540.  I am able to make outgoing calls but no incoming calls are comming in (getting a message that this number is not assigned).  In the RV220W I have added the SIP-TCP and SIP-UDP port forwarding to the UC540.
RV220W has the data dhcp server (10.9.8.3)
UC540 has the Voice dhcp server (10.1.1.1) and has an IP of data lan (10.9.8.1)
There is a static route in the RV220W from 10.1.1.0/24 to 10.9.8.1
In the RV220W I tried adding port forwarding for SIP-(TCP and UDP) to 10.1.1.1 (does not work) and 10.9.8.1  (does not work)...
Also mught be a VLAN problem but I'm not that great with VLAN...
In the RV220W Wan port I have my internet
RV220W Lan Port1 goes to my DataSwitch
RV220W Lan Port2 goes to UC540 expension port
1 REPLY
Hall of Fame Super Gold
Re: Added a RV220W in front of my UC540
You can take debug ccsip message on the UC to see if it receives the SIP message.
If it doesn;t, post in "small business router" as the problem would not be with the UC500.
207
