Community Member
All off-silte call directly goes to Auto Attendant
    Hello  everyone,
I have an issue with UC520. There is one PSTN line connected to the voice port 0/2/0, All dial out works fine,  All off-site calls goes directley to the Auto Attendant, however, interal dial-in works fine, I mean user can dial internal extension properly but not from offsite to insite.
I was wondering if any one can help me.
Here is the partal UC configuration:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.01.13 13:51:51 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 31685 bytes
dot11 syslog
dot11 ssid uc520-data
vlan 1
authentication open
dot11 ssid uc520-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip name-server 63.203.35.55
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
port 0/0/0
fallback-dn 301
port 0/0/1
fallback-dn 302
port 0/0/2
fallback-dn 303
port 0/0/3
fallback-dn 304
trunk group ALL_BRI
translation-profile outgoing PROFILE_ALL_BRI
voice call send-alert
voice rtp send-recv
voice service voip
sip
no update-callerid
voice class codec 1
codec preference 2 g729r8
voice class custom-cptone CCAjointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone CCAleavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice register global
max-dn 56
max-pool 14
voice translation-rule 4
rule 15 /^...$/ /0354434848/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^0/ /*/
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_BRI
translate calling 4
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
license udi pid UC520W-8U-2BRI-K9 sn FHK131827A2
archive
log config
logging enable
logging size 600
hidekeys
username cisco privilege 15 secret 5 $1$TC0B$LXMORw4u1vQpD/2eJdN4W1
username admin privilege 15 password 0 admin
username parham privilege 15 password 0 parham
ip tftp source-interface Loopback0
translation-rule 22
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
interface BRI0/1/1
no ip address
interface Dot11Radio0/5/0
no ip address
ssid uc520-data
ssid uc520-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
cptone AU
voice-port 0/0/1
cptone AU
voice-port 0/0/2
cptone AU
voice-port 0/0/3
cptone AU
voice-port 0/1/0
cptone AU
voice-port 0/1/1
cptone AU
voice-port 0/2/0
translate calling 1112
connection plar opx 398
description Configured by CCA 4 FXO-0/2/0-Custom-AA
caller-id enable
voice-port 0/2/1
description Configured by CCA 4 FXO-0/2/1-Custom-AA
caller-id enable
voice-port 0/2/2
description Configured by CCA 4 FXO-0/2/2-Custom-AA
caller-id enable
voice-port 0/2/3
description Configured by CCA 4 FXO-0/2/3-Custom-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711alaw
codec g711ulaw
maximum conference-participants 32
maximum sessions 2
associate application SCCP
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 300
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 398
b2bua
dtmf-relay rtp-nte
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 739
b2bua
dtmf-relay rtp-nte
no vad
dial-peer voice 90 pots
description AU-Mobile
preference 1
destination-pattern 04........
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 68 pots
description NSW Number
preference 1
destination-pattern 02........
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 69 pots
description TAS Number
preference 1
destination-pattern 03........
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 70 pots
description WA-SA-NT number
preference 1
destination-pattern 08........
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 72 pots
description QA-number
preference 1
destination-pattern 07........
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 74 pots
description International number
preference 1
destination-pattern 0011T
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 30 pots
description Australia-1800
preference 1
destination-pattern 1800......
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 31 pots
description Australia-1300
preference 1
destination-pattern 1300......
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 32 pots
description 13 Australia
preference 5
destination-pattern 13....
port 0/2/0
forward-digits all
dial-peer voice 67 pots
description mel-number
preference 1
destination-pattern 9.......
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 75 pots
description mel-Number
preference 1
destination-pattern 8.......
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 76 pots
description VIC number
preference 1
destination-pattern 5.......
port 0/2/0
forward-digits all
no sip-register
dial-peer voice 33 pots
description Emergency NUmber
preference 1
destination-pattern 0000
port 0/2/0
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
timeouts interdigit 7
system message UC520
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/CCMCIP/authenticate.asp
load 7906 SCCP11.9-2-1S
load 7911 SCCP11.9-2-1S
load 7931 SCCP31.9-1-1SR1S
load 7960-7940 P00308010200
load 521G-524G cp524g-8-1-17
time-zone 48
date-format dd-mm-yy
voicemail 300
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$NPt8$6I2moMN32fQoz083VCFm90
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 0.T
transfer-pattern .T
secondary-dialtone 0
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
create cnf-files version-stamp 7960 Dec 23 2013 10:55:20
ephone-template 15
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected Hold Endcall Trnsfer Confrn ConfList RmLstC Acct Park Select Join
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 5 dual-line
number 301 no-reg primary
label 301
description PhoneA Analog
name PhoneA Analog
ephone-dn 6 dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn 7 dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
ephone-dn 8 dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 10 dual-line
number 201 no-reg primary
pickup-group 1
label 201
description Extension 201
name Receptionist Receptionist
mobility
call-forward busy 300
call-forward noan 300 timeout 20
ephone-dn 11 dual-line
number 207 no-reg primary
label 207
description Extension 207
name None None
ephone-dn 12 dual-line
call-waiting ring
number 203 no-reg primary
pickup-group 1
label 203
description Extension 203
name Peter Steve
call-forward noan 300 timeout 15
huntstop channel
ephone-dn 13 dual-line
call-waiting ring
number 204 no-reg primary
pickup-group 1
label 204
description Extension 204
name Tim OConnor
huntstop channel
ephone-dn 14 dual-line
number 205 no-reg primary
pickup-group 1
label 205
description 205
name 205
ephone-dn 15 dual-line
number 206 no-reg primary
pickup-group 1
label 206
description 206
name 206
ephone-dn 16 dual-line
call-waiting ring
number 202 no-reg primary
pickup-group 1
label 202
description Extension 202
name David Holmes
huntstop channel
ephone-dn 17 dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn 18 dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn 19 dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn 43 octo-line
number 771 no-reg primary
conference meetme
preference 3
ephone-dn 44 octo-line
conference meetme
preference 2
no huntstop
ephone-dn 45 octo-line
conference meetme
preference 1
no huntstop
ephone-dn 46 octo-line
conference meetme
no huntstop
ephone-dn 49 octo-line
number C001 no-reg primary
conference ad-hoc
preference 3
ephone-dn 50 octo-line
conference ad-hoc
preference 2
no huntstop
ephone-dn 51 octo-line
conference ad-hoc
preference 1
no huntstop
ephone-dn 52 octo-line
conference ad-hoc
no huntstop
ephone-dn 55
number A801... no-reg primary
mwi off
ephone-dn 56
number A800... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address 4142.4DB8.0000
ephone-template 16
max-calls-per-button 2
type anl
button 1:5
ephone 2
mac-address 4142.4DB8.0001
ephone-template 16
type anl
button 1:6
ephone 3
mac-address 4142.4DB8.0002
ephone-template 16
type anl
button 1:7
ephone 4
mac-address 4142.4DB8.0003
ephone-template 16
type anl
button 1:8
ephone 5
mac-address 0024.97AA.E811
ephone-template 15
username "Receptionist" password receptionist
type 7931
button 1:10
--More--                    !
ephone 6
mac-address 0024.C4FC.4013
ephone-template 16
username "None"
type 7911
button 1:11
ephone 7
video
mac-address 000F.34FA.168B
ephone-template 16
username "steve" password petersteve
speed-dial 1 xxx label "Peter - Home"
speed-dial 2 xxx label "David - Mobile"
speed-dial 3 xxx label "Tim - Mobile AUS"
speed-dial 4 xxx label "Tim - Mobile USA"
type 7960
button 1:12
ephone 8
video
mac-address A40C.C394.B1F0
ephone-template 16
username "tim" password timoconnor
speed-dial 1 xxx label "David - Mobile"
speed-dial 2 xxx label "Peter - Mobile"
speed-dial 3 xxx label "Clare - Mobile"
type 7911
button 1:13
ephone 9
mac-address 0024.C4FC.5425
ephone-template 16
type 7911
button 1:14
ephone 10
mac-address 0024.C4FD.E27C
ephone-template 16
type 7911
button 1:15
ephone 11
video
mac-address 0007.5098.1AB6
ephone-template 16
username "holmes" password davidholmes
speed-dial 1 xx label "David - Home"
speed-dial 2 xxxl abel "Sue - Mobile"
speed-dial 3 xxx label "Peter - Mobile"
speed-dial 5 xxx label "Tim - Mobile AUS"
type 7960
button 1:16
ephone-hunt 1 sequential
pilot 501
list 202, 203, 204
final 300
timeout 8, 8, 8
no-reg pilot
statistics collect
description Sales
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Fri Nov 15 22:54:23 EST 2013^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
UC520#
428
