Community Member
Attendant Key LED Pattern (SPA500S 32-button Attendant)
I am trying to set up the SPA500S 32-button Attendant but having problems with the Attendant Key LED Patterns. I have found the codes to use (c=g, p=sb etc) but I don't know what to put in each option.
Application LED:    Serv Subscribe Failed LED:
Serv Subscribing LED:    SNRM Day Mode LED:
SNRM Night Mode LED:    Parking Lot Idle LED:
Parking Lot Busy LED:    BLF Idle LED:
BLF Ringing LED:    BLF Busy LED:
BLF Held LED:
All I really want is to know what to fill in each box that a standard company would want. Lights are always green unless someone is on a line, then it turns to red. If you are calling someone it flashes, if they are unavailable it is orange etc. Can someone tell me that have itset up as?
Also does these settings look right as well?
Unit 1
Unit 1 Key 1:
Unit 1 Key 2:
Unit 1 Key 3:
Unit 1 Key 4:
Unit 1 Key 5:
Unit 1 Key 6:
Unit 1 Key 7:
Unit 1 Key 8:
Unit 1 Key 9:
Unit 1 Key 10:
Unit 1 Key 11:
Unit 1 Key 12:
Unit 1 Key 13:
Unit 1 Key 14:
Everyone's tags (3)
1 REPLY
Community Member
Sorry the settings for the Unit 1 Key # didn't paste in. They all look like this:
fnc=sd+cp+blf;sub=4979@10.0.1.150;nme=Lisa
fnc=sd+blf+cp;sub=4980@10.0.1.154;nme=Joellyn
fnc=sd+blf+cp;sub=4981@10.0.1.155;nme=Tammy
fnc=sd+blf+cp;sub=4982@10.0.1.156;nme=Dan
etc...
2360
