Community Member
auth fail
hello,
after upgrading the pack software 8.6.1 of UC520 , the ip phones shows auth fail. how can i resolve this problem?
Hall of Fame Super Gold
auth fail
Remove the load statements under  telephony-service.
You can search the "ip telephony" forum for more information about the error.
Community Member
auth fail
why i should remove the loads? there are not the phone 's firmware?
auth fail
Because they specify firmware version that do not load successfully.
Community Member
auth fail
do you mean i must go to phone load management in CCA, deleting the phone loads and then uploading the phone loads? if i must do this with CLI what command should i use?
Re: auth fail
Just remove the commands by any mean that you like, and the phones will not attempt to load new firmware at boot.
Community Member
auth fail
when i remove the commands  will the phones work with the old firmware or not?
auth fail
Answered above already.
Community Member
auth fail
hello,
i didn't find how can i will remove the load statement. have you an idea about the command to do that? thanks
Re: auth fail
telephony-service
no load xxx.
Community Member
Re: auth fail
I executed the command no load but there is still the same problem.
379
