Community Member
Auto-answer
Hello all,
I would like to setup an extension to auto-answer all calls.  I can't find where to do that in the CCA or any other place.  I've searched the user guides and only found one thing relating to auto-answer and it had to do with Do No Disturb:
"•If both DND and auto-answer are enabled, only intercom calls will be auto-answered."
Does anyone know where I can enable auto-answer?
-Renato
1 REPLY
Re: Auto-answer
If you confiugre 'intercom' under a DN, it will auto answer when the DN is rung.  Does that help for what you're trying to accomplish?
438
