12-28-2010 05:12 PM - edited 03-21-2019 03:27 AM
Hi All,
what is the best way to insert an additional 0 to all outgoing numbers on a UC560?
thanks
12-28-2010 05:38 PM
The manual addition of translation rules and profiles is not possible via CCA.
12-28-2010 06:07 PM
how abt if i SSH into the box?
12-28-2010 06:27 PM
You can, but you would be opening up a can of worms because CCA already applies "called" and "calling" translation patterns. If you are not familiar with CLI, translation profiles, rules and dial peers you can end up in a situation where you can't make outbound calls.
12-28-2010 07:02 PM
this is fine, i can rebuild from backup, it is not live environment.
12-28-2010 07:06 PM
Good luck, translation rules are not fun.
12-29-2010 07:43 AM
Would need to know more about exactly what you are trying to do, but your translation rule could look something like:
rule 1 /^0/ /00/
This rule would add an additional zero to any number that began with a zero.. ie - 0555666 translate to 00555666
12-29-2010 02:56 PM
Thx Darren i'll give it a try.
01-01-2011 02:33 PM
Why don't you use global config num-exp command: num-exp .* 0.*
Regards.
Alain.
01-02-2011 03:07 AM
Here's an example of adding an extra zero to an incoming number and removing it for outgoing:
#remove PSTN access digit to outgoing called numbers
voice translation-rule 1
rule 1 /^0/ //
voice translation-rule 4
rule 1 /^301234567$/ /501/
# add PSTN access digit to incoming calling numbers
voice translation-rule 5
rule 1 // /000/ type international international
rule 2 // /00/
voice translation-rule 6
rule 1 /.*/ /301234567/ type unknown unknown
voice translation-profile incoming
translate calling 5
translate called 4
voice translation-profile outgoing
translate calling 6
translate called 1
translate redirect-called 6
Remark : changing translation rules on CLI drops them from the CCA-radar. Any changes have to made on CLI from then on.
