B-ACD Queue Question
Hello Cisco Faithful,
I have a question about information that the Command "show ephone-hunt 50" shows.  Each agent has a line, "off-hook agents=0, or 1"
One or more of the agents show "off-hook agents=-1".  Can anyone explain the meaning of "0", "1" or "-1"?
Here is the "show ephone-hunt 50" :
AcmeCo.#show ephone-hunt 50
Group 50
    type: longest-idle
    pilot number: A300, peer-tag 20327
    list of numbers:
        111, aux-number AA300A4900, # peers 1, logout 0, down 0
            on-hook time stamp 72068624, off-hook agents=1
            peer-tag  dn-tag  rna  login/logout  up/down
             [20326     538    2       login      up  ]
        117, aux-number AA300A4901, # peers 1, logout 1, down 1
            on-hook time stamp 46889278, off-hook agents=0
             [20328     468    0       logout     down]
        125, aux-number AA300A4902, # peers 1, logout 1, down 1
            on-hook time stamp 72163943, off-hook agents=0
             [20329     470    0       logout     down]
        128, aux-number AA300A4903, # peers 1, logout 1, down 1
            on-hook time stamp 5793, off-hook agents=0
             [20330     530    0       logout     down]
        184, aux-number AA300A4904, # peers 1, logout 1, down 1
            on-hook time stamp 72060538, off-hook agents=0
             [20331     474    0       logout     down]
        191, aux-number AA300A4905, # peers 1, logout 1, down 1
            on-hook time stamp 72158570, off-hook agents=-1
             [20332     516    0       logout     down]
        194, aux-number AA300A4906, # peers 1, logout 1, down 1
            on-hook time stamp 71850416, off-hook agents=0
             [20333     502    0       logout     down]
        212, aux-number AA300A4907, # peers 1, logout 1, down 1
            on-hook time stamp 71588403, off-hook agents=0
             [20334     582    0       logout     down]
        213, aux-number AA300A4908, # peers 1, logout 0, down 0
            on-hook time stamp 72131156, off-hook agents=0
             [20335     595    0       login      up  ]
        211, aux-number AA300A4909, # peers 1, logout 1, down 1
            on-hook time stamp 63666367, off-hook agents=0
             [20336     593    0       logout     down]
    preference: 0
    preference (sec): 7
    timeout: 8, 8, 8, 8, 8, 8, 8, 8, 8, 8
    description: *** CCA BACD ***
    display-logout: All agents logged out
    hops: 2
    E.164 register: no pilot
    auto logout: 3 type: both
    stat collect: yes
    number of calls in queue: 4
    callqueue display: continuously
    debug: no
Thank you, Paul
Everyone's tags (3)
Hall of Fame Super Gold
Agent on call should be 1, otherwise 0. Negative value can be a bug, possibly cosmetic only.
Hi Paul,
off-hook agents is the number of the agents 1 or more sharing this DN which are off-hook. 0 means nobody, 1 means if the agent is offhook, -1 usualy means DND mode (and maybe - cannot remember if the agent is logout and is offhook or another logout mode also) for this agent as I remember.
HTH,
Alex
*Please rate helpful posts.
581
