Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
BACD busy prompt how do w change it or can we get it not to play?
Hi There,
We have setup a BACD for a client, and the busy prompt is a very American defaul sorry all our agents are busy one.
The client doesnt want this or like it.
How can we change the prompt using CCA or other SBC support supported tools?
Alternatively can we get it not to play?
I tried setting the play busy at 90 secs and timeout to voicemail at 60 secs but teh message still plays at which is what it was set to before I changed it.
Graeme
2 ACCEPTED SOLUTIONS
Are you able to locate the file thats playing (look in flash:/bacdprompts/) and try to replace it with your own?
I remember the CCA GUI used to allow you to change Welcome and Transfer prompts, but the fact was Welcome never plays in UC500 drop through mode so that wont help.
Re: BACD busy prompt how do w change it or can we get it not to
I've done it before and it works fine. Like Steven said find the file it's playing and overwrite it with your own custom file. Just make sure it's in the correct format. g711ulaw 8bit 8 khz (pretty sure that's right)
1112
