I have a problem trying to configurate a be6000, i have a Router, a Switch and my BE6000, but when i'm trying to configure the NTP in my BE6000, it doesn't work, i have to say that i'm redirection my BE6000 to my Router to take the NTP...
someone knows the configuration that i must have into my Router?
and if i have to have internet connexion or no? is just a doubt bcs i really don't know what else to do
No, internet connection is not mandatory, if you wish to register ELM online, then yes, you'll need it.
As for NTP, you can get the configuration by just searching CCO for NTP configuration.
java
if this helps, please rate
