Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
block specific incoming call number FXO
I try to block incoming calls from specific number on fxo
here's what I did :
voice translation-rule 11000
rule 1 reject /**********/    (I enter my phone number)
voice translation-profile CALL_BLOCK
translate calling 11000
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
call-block translation-profile incoming CALL_BLOCK
call-block disconnect-cause incoming invalid-number
port 0/1/1
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
I tried 2 methods, one on my fxo port 0 and one of my fxo port 1,
when i call port 0 everything's normal but when I call port 1, it takes like 5 rings to get to the phone and it shows anonymous as the caller Id instead of my phone number
why it's not working ?
Hall of Fame Super Gold
Apply the translation-profile under voice-port, not dial-peer.
in this ???
when i try to, i can't enter the cmd line
voice-port 0/1/0
trunk-group ALL_FXO 64
cptone CA
connection plar opx 296
description Configured by CCA 4 FXO-0/1/0-Custom-OP
caller-id enable
voice-port 0/1/1
cptone CA
description Configured by CCA 4 FXO-0/1/1-Custom-OP
caller-id enable
voice-port 0/1/2
cptone CA
description Configured by CCA 4 FXO-0/1/2-Custom-OP
caller-id enable
voice-port 0/1/3
cptone CA
description Configured by CCA 4 FXO-0/1/3-Custom-OP
caller-id enable
when i refer to this it says to user dial-peer : https://supportforums.cisco.com/thread/2020843
I can tell you what works, then it's up to you  to try it or not.
like I told you when I try to enter the command line under Voice-port cisco ios won't let me enter the command..
Re: block specific incoming call number FXO
That is what command?
Anyway that method of blocking call might not work with FXO at all.
I follow this doc :http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftgwrepg.html#wp1038689
1405
