Community Member
Borblems with IPSEC
I can not extablish IPSEC betwean 2 UC500 [localtion 1 and location 2]
Any idea?
Re: Borblems with IPSEC
crypto isakmp key address 89.212.19.18
set peer 89.21.19.18
I just see a typo.
should be
set peer 89.212.19.18
You left out the second 2 in 212 on the set peer command.
Let me know if that helps.
Community Member
I don't understand.....
Community Member
Dejantrop.
I would advise you to state your problem clearly and explain in detail what is working and not working. A two line description, followed by some out of context configuration files, won't take you far in these forums.
We try to do our best to answer point questions, but we need those point questions.
Marcos
Community Member
Which lines I must change? In to what?
4063
