Community Member
Call forward issue
Hi all, I have an issue with call forward. When a user makes a call forward to another set - ex: set B - and if set B wants to call to set A - set that have call forward activated - the call goes, again, to set B. Shouldn't the target set of the call forward be the only one that can call to him?
Ex: Set A call forward all calls to set B.
      Set B tries to call to set A but since is call forwarded to set B he cant - call makes loop to set B.
      Expected Result:
      Set B should be the only one that can call to set A.
On other PBXs this is the normal behavior, is there a way to put this right?
Thanks on advance.
Best Regards,
Jose Carlos
Community Member
Re: Call forward issue
We currently do not have a way to "ignore" the call forward settings, even if these cause a loop.
Marcos
Community Member
Ok Marcos, thanks for your reply.
Best Regards,
Jose Carlos
803
