Caller-ID translation on UC560 and UC540
We are trying to get our caller-ID to display a dummy DN or at least the translated number. Here's the example:
Manager from UC540 system calls me here in NY: 912125551000. My caller ID shows "From 2125551000" on our UC560 system. What I would like to have done is show "1001" instead of "2125551000". So the idea is to create a translation rule to do this. Here's an example:
voice translation-rule 3000
rule 1 /2125551000/ /1001/
voice translation-profile CUSTOM_IN
translate calling 3000
dial-peer voice 4000 pots
corlist incoming call-internal
description CUSTOM inbound caller id translation
translation-profile incoming CUSTOM_IN
incoming called-number 212555....
Is there anything else I need to do?
Re: Caller-ID translation on UC560 and UC540
Renato,
Everything you have listed is correct.  I would think that you would also want to add a "translate called" to the translation profile to direct the incoming call..  Not sure since I don't know your full config.
Thank you,
Darren
Didn't work. What is the difference between called number and calling number?
Renato,
Translating the "calling" number on a call will modify the Caller-ID for that call.
Translating the "called" number on a call will modify the the number that was dialed.  Usually used on an outgoing call to remove the "steering" digit, normally a 9.  On an incoming call, the "called" number is modified to redirect the call to a extension, hunt group, or auto attendant.
Thank you,
Darren
Do I have to map the translation-profile to a pots trunk group or something so that it can read my translations? How does the system know to match the caller id of incoming calls to my translation rules?
OK, we might need to backup a little here...  Is the call coming in over an FXO port, T1/E1.......  I am assuming it is not a SIP trunk since your orignial email showed a 'pots" dial-peer.
The translation profile should be on the incoming dial-peer.  When that dial-peer is matched, it will process the call though the translation rule.
Thank you,
Darren
The call is coming over a T1/E1, though I would like to include it in the FXO as well.  I'm also going to need to create one dial-peer for sip for other offices so let's include the three examples: Calls coming over T1/E1, FXO, and SIP.
-Renato
For SIP and/or T1/E1
What you had listed in the beginning is correct.
voice translation-rule 2000
rule 1 /6665554545/ /1001/    <-Changing incoming caller ID
voice translation-rule 2001
rule 1 /8005551212/ /5011/    <-Sending call to blast group
voice translation-profile TEST_ONE
translate calling 2000
translate called 2001
dial-peer voice 1006 pots
  translation-profile incoming TEST_ONE
  incoming called-number 8005551212
For FXO, you will need to put the the translation on the voice ports.
voice-port 0/1/0      <-Will have to do this for each FXO port.
*** Warning: If you are using CCA only, or are not a "UC Specialized" partner, modifications though CLI can void support for CCA when calling into support in the future.  If you have questions about this, or need asistance please call into support. ***
Thank you,
Darren
1308
