Community Member
CCA 2.2 (5) -java.lang.NumberFormatException: For input string: "8.04_"
when entering Phone Configuration in CCA 2.2.(5) I've  got this error:
I've just successfully upgraded to 8.04 ...
Any Ideas?
Ognian
Community Member
Re: CCA 2.2 (5) -java.lang.NumberFormatException: For input stri
Hi Ognian,
To pin point the root cause for this Java exception, we would need to take a look at the log file. Please open a TAC case, and an engineer should be able to help you.
Thank you,
Anna
Community Member
Hello Anna,
unfortunaly there is no service contract for this particular box, so I can't open a TAC. I've attached the logs, maybe you can tell me if this is a known problem and when it will be fixed. As far as I can say CCA is complaining about the "_" in the version number "8.0.4_".
Thanks a lot
Ognian
Community Member
Hi Ognian,
I will take a look at the logs.
Please stand by,
Anna
442
