Community Member
CCA 3.2.2 Not Building Config Correctly?
Having an issue with the configuration of a UC540 using CCA 3.2.2.  The issue is that the configuration is not built correctly - voice VLAN, routing, ACLs, more are all incomplete/incorrect.
Example - default VLAN is changed to, voice VLAN is changed to  Default VLAN is changed correctly, voice VLAN is not built.  Various parts of config point to the original voice VLAN, other parts to the new voice VLAN.
I have repeated this multiple times after factory reset of CUE and CME.  If needed, I can provide the steps taken to factory default the box.
I can provide screenshots of each of the pages from the initial device discovery, each step of configuration, and the configuration file produced from those steps.
Is anyone else experiencing this issue?  I have searched this forum and the web and am coming up with nothing.
Is there a reasonable way to fix these issues or will the configuration have to be done manually, that is through CLI?
