Community Member
Change the LED color on SPA525G when DND is enabled
Is it possible to change the LED colors do Red when the DND setting is on?
1 REPLY
Re: Change the LED color on SPA525G when DND is enabled
No, the color layout for the functions is fixed
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
182
