Community Member
Changing the Display Background spa502G and 504G phones
Hi All.
Is it possible to customize a background image for SPA50XG phones?  By default, there is nothing.
In cisco spa500_admin guide says:
STEP 1 Copy the image to a TFTP or HTTP server that is accessible from the phone.
STEP  2 Log in to the configuration utility.
STEP  3 Click Admin Login and advanced.
STEP  4 Click the Phone tab.
STEP  5 In the Select Background Picture field, select BMP Picture.
I was trying to login using ip of the phone(step 2), but it doesn't give an option for Admin login, only screen where you can't make changes. Is there something I need to enable to use that?
For Step 1, can I use local pc as tftp server to send a pic? do I need to add something on a phone to enable that?
Thanks for your answers.
