07-18-2013 09:48 AM - edited 03-21-2019 07:34 AM
Dear all,
I have a question concerning Cisco BE6000 licensing. I'ts clear that MD server support 1000 users and 1200 devices.
In this case, Can I add additional phones from UPM or CUCM without being associated to a user ? Means,that I can have 200 additional phones without users and 1000 users associated to a phone.
Can I add a phone directly from CUCM and not from UPM ? Does UPN updated directly its users and phone directory from CUCM ?
Kindly reply, it's an urgent request
Solved! Go to Solution.
07-18-2013 12:37 PM
BE6000 licensing is based on licensing users and unassociated devices. An unassociated phone still consumes the "User Connect License" that is required for that type of phone. You are correct in saying that the MD server does support up to 1200 devices, so as long as you are licensing and deploying no more than 1,000 users (think total and configured licenses/users) and 1,200 devices... Then you are in good shape.
I presume that you are using Cisco Prime Collaboration Provisioning (PCP) instead of the older UPM. With CPC, you can add phones and users into UCM and they will be "synced" over to CPC at the next configured sync schedule. No problem.
It is still a good idea, from a change management perspective, to add/move/change user services in CPC. It will keep track of everything that has been done to/for a user.
07-18-2013 12:37 PM
07-19-2013 11:40 AM
Thank you Christopher, much appreciated for the information.
