Cisco VoIP System does not answer first caller.
     I'm having an issue with my phone system in my office. If one person calls, the auto-attendant does not answer, and just keeps ringing, however if a second person calls, it will answer the second person. I did a couple of debug commands, and it doesn't even seem to pickup any information when the first caller calls, but when the second caller calls I get a whole whack of information from the debugging.
Here is the version of what I'm running for my phone system.
sh version
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(9)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 16-Jun-06 22:22 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
SDBREM-2821-01 uptime is 1 hour, 13 minutes
System returned to ROM by reload at 09:13:26 EDT Tue Sep 1 2009
System restarted at 09:14:28 EDT Tue Sep 1 2009
System image file is "flash:c2800nm-spservicesk9-mz.124-9.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX0923A1LF
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
If
Cisco
Thanks.
Re: Cisco VoIP System does not answer first caller.
Hi Christopher,
It seems that you may be hitting different inbound dial peers for the AA calls. I would check that first. Having said so, these forums are for Small Business products. The 2800 does not fall into this category. Please refer to Netpro for ISR support:
http://forum.cisco.com/eforum/servlet/NetProf?page=main
Marcos
Sorry about that.
Thanks, Marcos.
3350
