Community Member
CME
Due to a change in the CUE GUI it is not possible to use the default webinterface http://10.1.10.1/ to administer the CFA/CFNA/CFB for extensions.
How can the endusers manage these functions while away from the phone?
Installing CCP/CCA/OfficeManager on all desktops is not an acceptable solution.
regard
Thomas Kiel
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_0/rel_notes/rel_notes.html
Removal of Support for Cisco Unified Communications Manager Express GUI Functionality
Beginning with Cisco Unity Express 8.0, the Cisco Unity Express GUI no  longer provides functionality for configuring Cisco Unified  Communications Manager Express. Cisco recommends using Cisco Configuration Professional (CCP) to configure Cisco Unified Communications Manager Express.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: CME
http://192.168.10.1/ccme.html ???
ALso the Phone can do CFAll
Re: CME
Community Member
Re: CME
you are right. http:///ccme.html works normally.
But in this instance there is a failure - I will investigate further. The webpage only shows a message in top left corner saying "VIEW WINDOW", thats it.
I tried upgrading a spare UC520 as well, there it all works fine. This must be an upgrade issue.
Thx for the quick reply.
Thomas
Community Member
Re: CME
Found the problem.
Under telephony-service:
directory entry 7 0004523588920 name testperson, "lokalnr"
changed to
directory entry 7 0004523588920 name testperson, lokalnr
and now it works
736
