02-18-2009 02:31 AM - edited 03-21-2019 12:57 AM
Is it possible to configure an FXO voice port to be exclusive used by a user or a group of users?
Tarik
Solved! Go to Solution.
02-18-2009 06:19 AM
Tarik,
This is possible to implement in multiple ways. I will proceed with explaining the two that are most common:
1) Port segregation based on dialed number: You create POTS dial-peers with specific destination patterns, and assign the appropriate FXO ports.
Example:
dial-peer voice 5500 pots
destination-pattern 8.T
voice-port 0/0/0
This dial peers is accessible to anyone, so you would only give the dial string to the corresponding users (you would ask them to always dial the prefix "8")
2) A more secure, convenient way of doing this is using Class of Restriction, which effectively achieves dial plan partitioning.
Example:
dial-peer cor custom
name FXO
dial-peer cor list FXO-Only
member FXO
destination-patter 9.T
voice-port 0/0/0
corlist outgoing FXO-Only
ephone-dn 1
number 201
description Joe Doe
corlist incoming FXO-Only
Hope this helps,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
02-18-2009 10:54 AM
To add to Marcos's comments...
Here is how you configure COR list.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
02-18-2009 06:19 AM
Tarik,
Example:
voice-port 0/0/0
Example:
name FXO
member FXO
voice-port 0/0/0
ephone-dn 1
number 201
description Joe Doe
Hope this helps,
Marcos Hernandez
Cisco Systems, Inc.
02-18-2009 10:54 AM
09-27-2009 11:14 AM
I wanted to add to the good advise you received from two experts (Marcos and Steven) with a way to group some FXO ports in a trunk group and some others in another, and then assign the PSTN Trunk Group to the outgoing dial plan access codes you desire.. Oh and did I mention you can do this all with CCA 2.1?
https://www.myciscocommunity.com/docs/DOC-10701
Steve DiStefano
SE, US Field Channel Sales
