10-08-2014 03:38 PM - edited 03-21-2019 08:24 AM
I lost the password and login of my ip phone SPA 303
So i cant do anything with it
how can i reset the login and password and or get a new one (or get rid of it altogether).
pls
help
10-09-2014 01:48 PM
anybody out there?
this must happen all the time
10-31-2014 02:20 AM
Do reset to factory default. Note that it can be disabled by configuration. If it is disabled on your device ask device administrator to ublock it or perform reset by self.
If you are only administrator of the device, you blocked the reset to factory default feature and you forgot the device password, you are out of luck.
