Community Member
Delete messages from a voice-mail box
Is there any way to delete all messages in a voicemail box? Perhaps a CLI command?
Everyone's tags (3)
Community Member
Re: Delete messages from a voice-mail box
You can do two things from the CUE CLI:
1.     Under the voicemailbox, set an expiration timer to 1 day for all messages. This will delete all messages in it at the end of the day :
voicemail mailbox owner marchern
expiration time 1
Notice you might not want this to be a permanent setting.
2.     Simply delete the mailbox and re-create it as below :
no voicemail mailbox owner marchern
Marcos
Community Member
Thanks for the quick reply!
Here is my current config for the mailbox:
voicemail mailbox owner "support" size 12000
description "Support Mailbox"
expiration time 1
login pinless any-phone-number
zerooutnumber "200"
end mailbox
The expiration time is set to 1 but the messages still remain. Any suggestions?
Thanks!
Community Member
You have to wait 24 hrs after the message was left and checked (can't be a new message).
Marcos
Community Member
I've had that config for about 3 months.
Does it matter if the message is never checked? All voicemails are e-mailed via SMTP and therefore no one ever logs into the CUE.
Community Member
I am almost certain this might be the reason, but not 100% sure. You can open a TAC case and ask the engineer to submit an enhancement request, since the behavior should be as you describe it.
Marcos
CUE does not automatically delete messages from the voicemailbox. Only the owner of a personal mailbox can delete messages
in the mailbox and members of a GDM can delete messages in the mailbox.
However you can configure IMAP which gives you the ability to read, mark as read or unread and delete voicemails.
The voice-mail messages are downloaded as attachments to e-mail messages. Subscribers can access the voice-mail messages
over the network or can download them selectively. If the messages are downloaded, subscribers can play them locally using standard
media players without requiring a connection to Cisco Unity Express.
So if you access your mailbox via IMAP you can delete the VMs you want to. Please refer to the following link for more information:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/cliadmin/ch_imap.html#wp1064742
Hope this helps!
Tere Stevens.
Regards, Tere. If you find this post helpful, please rate! :)
8877
