Community Member
dial peer for *67 (outbound caller id blocking)
hi
how do you configure *67 dial peer? i was told that the telco doesn't block *67 from their network. outgoing line is pri circuit.
any ideas? thank you.
1 REPLY
Hall of Fame Super Gold
You don't need that with PRI. Just configure caller-id block code under telephony-service, and IOS takes care of the rest. The code can be very well *67 if you want.
900
