dial-peers and outgoing calls
I created 2 dial peers:
UC520(config)#dial-peer voice 104 pots
UC520(config-dial-peer)#destination-pattern 9.T
UC520(config-dial-peer)#port 0/1/0
UC520(config)#dial-peer voice 105 pots
UC520(config-dial-peer)#port 0/1/1
what I want to do is,
1. IF a number starts with 1 or 9, It must directly go to the FXO port, which my analog central connected. For example if I dial 112, it will forword it to one of my fxo port. In my setup, if I dial 9112, I can call my analog central's local number.
2. On outgoing calls, x user must go on port 0/1/0 and y user must go on port 0/1/1. How can I do that?
I don' see connection cli under the dial-peer voice 104 pots. IOS version : uc500-advipservicesk9-mz.150-1.XA
1 REPLY
Re: dial-peers and outgoing calls
For question 1, you can create another dial-peer that works for digits starting with 1.
UC520(config)#dial-peer voice 107 pots
UC520(config-dial-peer)#destination-pattern 1.T
For question 2, this can be done with corlist.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
320
