dial plan for toll free number 800
Anybody know's how to configure the dial plan for calling toll free number "800"
thanks,
Angelo
Everyone's tags (2)
Hi Angelo,
Which country are you talking about?
Also are you using CCA to configure the system??
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David,
Singapore Dial Plan
yes im using CCA to configure
I need to call USA toll free number starting 800
Angelo
Re: dial plan for toll free number 800
Hi Angelo,
That's not a CCA issue
Basically you will have an international dial-peer, this will cover all
destinations irrespective of the type of call tolled or toll free.
I would say with almost 100% certainty that your problem is Telco related.
Can you tell us who you are connected with and how? Is it Singtel, StarHub
or anyone of the many SIP based ITSP's??
More info can assist us in helping you get to the bottom of it....
Cheers,
David Trad
"Sent from my Acer Iconia A500"
On May 30, 2012 9:33 PM, "castro.angelo" <
Hi David,
Were using singtel line.
I try to configure on the dial plan the 800 toll free number and i notice
that i can call if i remove the mobile phone number starting with 8,
but i cannot call the mobile phone starting with 8.
here in singapore the mobile phone are starting with 8 & 9.
Angelo
were using ISDN 10 line
Hi Angelo,
What is the actual dial string you dialling?
Is it "access code - international code - international prefix - full
national number" ?
For instance 0-001-1-800600700500 ?
Cheers,
David Trad
On May 30, 2012 9:52 PM, "castro.angelo" <
Hi David,
Press Line then
just dial the toll free number
800-101-2597
I try the 1-800-8486933
can call but when dial the
800-101-2597
cannot
Angelo
Hi Angelo,
You need to dial the 1 because it is an international call and number, if
you don't Singtel won't know which country you are calling, this is normal
and is the same for everyone around the globe.
Cheers,
David Trad
On May 30, 2012 10:03 PM, "castro.angelo" <
Hi David,
I try dial 1 first but i goes to other toll free numbers.
example 800-101-2597 is the correct number but if i add
1-800-101-2597 is different already.
Angelo
Hi Angelo,
Try dialling the following: 001- 1-800-101-2597
Cheers,
David Trad
On May 30, 2012 10:19 PM, "castro.angelo" <
Hi David,
Its say the number you dial is not valid.
Angelo
Can you please do a "debug idsn q931" and post the results please, and if
possible post your configuration with all usernames and passwords removed.
Cheers,
David Trad
On May 30, 2012 10:31 PM, "castro.angelo" <
2509
