DID HELP
suraj12345
For incoming Calls:
voice translation-rule 1
rule 1 /^43930/ /80/
voice translation-profile incomingcalls
translate called 1
dial-peer voice 60 pots
translation-profile incoming incomingcalls
incoming called-number 43930..
direct-inward-dial
For Outgoing Calls:
voice translation-rule 2
rule 1 /^80/ /43930/
voice translation-profile outgoingcalls
translate calling 2
dial-peer voice 61 pots
translation-profile outgoing outgoingcalls
preference 1
destination-pattern 0T
port 0/3/0:15
no sip-register
Incoming DID caller id is working fine
Out going caller id still displays pilot Number
What is wrong for outgoing caller id please Advise
8 Replies 8
I bet you your PSTN provider is overwriting it. Please post a "debug isdn q931" and you'll see that the calling number is going out correctly, but your provider is modifying it.
Let us know,
Marcos
Thanks i will try to talk to my Service provider
Check the ISDN debugs first, to be sure.
Marcos
Out going calls  Debug
Called number 0507840168- Clid 4393000
Jun  8 17:38:50.700: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x0 0x1, Calling num 4393098
Jun  8 17:38:50.704: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is
  0x0 0x1, Called num 0507840168
Jun  8 17:38:50.704: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x016B
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                 Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Progress Ind i = 0x8183 - Origination address is non-ISDN
         Calling Party Number i = 0x0180, '4393098'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '0507840168'
Jun  8 17:38:50.740: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
16B
Jun  8 17:38:54.796: ISDN Se0/3/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x81
6B
Jun  8 17:38:57.672: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
816B
        Cause i = 0x8091 - User busy
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jun  8 17:38:57.672: ISDN Se0/3/0:15 Q931: call_disc: PI received in disconnect;
Postpone sending RELEASE for callid 0x80EC
Jun  8 17:38:58.860: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x016
B
Jun  8 17:38:58.876: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x816B
INcoming
got a call   from  '043975099' i have received the call  in 4393098
Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x0083, '043975099'
                 Plan:Unknown, Type:Unknown
        Called Party Number i = 0xC1, '4393098'
                Plan:ISDN, Type:Subscriber(local)
Jun  8 17:47:24.780: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
8EC
        Channel ID i = 0xA9838B
                Exclusive, Channel 11
Jun  8 17:47:24.792: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x88
EC
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Jun  8 17:47:31.036: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x88E
C
Jun  8 17:47:31.072: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x08EC
Jun  8 17:47:34.612: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
816D
        Cause i = 0x8290 - Normal call clearing
Jun  8 17:47:34.612: ISDN Se0/3/0:15 Q931: call_disc: PI received in disconnect;
  Postpone sending RELEASE for callid 0x80EE
Jun  8 17:48:04.612: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x816
D
Jun  8 17:48:04.612: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x016D
Jun  8 17:48:43.048: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x
88EC
        Cause i = 0x8090 - Normal call clearing
Jun  8 17:48:43.108: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x08E
C
Jun  8 17:48:43.112: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x88EC
This is my new rule
My extensions start from 000 to 099
rule 1 /^43930/ /0/
rule 1 /^0/ /43930/
translate called 1
translate calling 2
My isp says i need to add 04 to my did
So which translation profile i have to use it is 04
rule 1 /^43930/ /0/
This rule would replace something that begins 43930 with 0, essentially taking away 43930.
rule 1 /^0/ /43930/
This rule would replace 0 with 43930.  It looks like you want to prefix something.
If you want to prefix a 04, you might want something like this.
rule 1 /\(^43930..$\)/ /04\1/
This rule would take something that begins 43930, has two digits following, and adds 04 to the beginning.  An example would be...
4393012 would turn into 044393012.
Thanks Steven
It works out Appreciated.
MY DID Caller ID issue is solved
Only a small issue I am facing is when you call somebody and the called party send a BUSY TONE , Ephones is disconnecting after 5 secs, even if the debug shows it is disconnected , in the Voice port, I changed disconnection time to 0.Then also the same.
It would be best to have this next issue in a new discussion so that others could find the answers better.  Would you mind starting up a new discussion?  I will help you with this in there.
I will do it
