Community Member
Digit press timing
Is it possible to adjust the timing when dialing a call.
For example, dialing 9+22234588 then holding for a few seconds to find the last couple numbers causes the call to fail.  I'd like to be able to adjust the timer to allow for a longer wait time when entering digits.  Is this possible?
1 REPLY
Re: Digit press timing
please take a look at the Interdigit Short Timer parameter, it's 3 seconds by default so you may want to increase it a little bit...
More info here:
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa500_admin.pdf
Thanks!
-nacho
436
