Community Member
Direct Specific Extensions to Specific Outgoing FXO
We have a site with 6 FXO lines.  They want extensions 201 and 202 to make outgoing calls on 0/1/0, 0/1/1, or 0/1/2.  All other calls should go out 0/1/3, 0/2/0, and 0/2/1.
What is the easiest way to accomplish this?
Community Member
Re: Direct Specific Extensions to Specific Outgoing FXO
The easiest way to do this is to configure the system in hybrid mode. Extensions 201 and 202 will have a unique button-to-line mapping (key system), while the other extensions can do PBX with the rest of the PSTN lines.
Marcos
Community Member
Are there instructions anywhere showing how to set that up?
Thanks for the help.
Community Member
Yes, the complete First Look v1.4 Lab Guide has this information in Appendix B. Also, the scenario based labs have an example that you can use as a reference:
https://www.myciscocommunity.com/docs/DOC-1525
Marcos
2968
