07-19-2011 05:39 PM - edited 03-21-2019 04:22 AM
I am trying to configure the two front-desk phones in our office so that call-waiting is not active on them.
Right now I have them setup in a call-blast group. Our main incoming DID is configured to go straight to the group - that is working and both phones are ringing. However, if someone answers the call on either phone, and another call comes through, the person talking on the first call hears the call-waiting beep, and the other phone does not ring. Additionally, the person calling never gets to voicemail. It just rings and rings.
Here are the relevant pieces of the configuration:
voice hunt-group 1 parallel
final 600
list 600,601
timeout 16
pilot 511
ephone-dn 10 dual-line
no call-waiting beep
number 601 no-reg primary
label 601 - Front Desk 2
description Front Desk 2
name Front Desktwo
translation-profile incoming CallBlocking
ephone-dn 155 dual-line
no call-waiting beep accept
number 600 no-reg primary
label 600 - Main Line
description Incoming Calls
name Front Deskone
call-forward busy 500
call-forward noan 500 timeout 18
Could anyone help me to successfully disable call waiting, OR give me another idea for how I should be configuring this so that the call stream works as follows:
call comes in -> both phones ring -> somebody answers on phone A -> second call comes in -> phone B rings
And also if nobody answers, or if both of those phones are tied up, the voicemail for phone A should pick up (I have that setup as our main public mailbox).
07-19-2011 06:22 PM
Simply use a shared octo-line DN.
No voice hunt-group is necessary.
07-20-2011 06:50 PM
Hi Tamer,
To expand further on what Paolo has suggested, this might be a better option for you
If this is FXO line then the following Scenario could be applied:
voice-port 0/1/0
trunk-group ALL_FXO
supervisory disconnect dualtone mid-call
compand-type a-law
cptone AU
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx immediate 500
impedance complex1
description Configured by CCA 4 FXO- 0/1/0-BG
caller-id enable
NOTE: THis is setup for Australian FXO settings, please make sure if it is FXO you are using that you make the appropriate adjustments on your configuration, replicating the above may break your setup.
ephone-dn 50
number 500 secondary
no-reg both pickup-group 1
label Line 1
description Line 1
name Line 1
preference 1 secondary 3
call-forward busy 6XXX <------------- *** See Notes
call-forward night-service 6XXX
call-forward noan 6XXX timeout 30
no huntstop
hold-alert 60 originator
night-service bell
NOTES ***: This is to do a directed transfer to a VM box without it having to ring the extension, you would need the following configuration for it:
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
And the Rule
voice translation-rule 2002
rule 1 /^6/ //
If it is BRI/PRI Services you are using, this is then just controlled via your Translation Rules/Profiles you have in place, which it looks like you have there.
Your configuration shows me that you have a Blast Group setup, which then points to a Virtual DN, which in theory should be assigned to a button... If this is correct then you do not need the blast group at all, you just need the virtual DN's and assign them to a button, if you do not have enough button real-estate then you can overlay it on a button and assign the other lines as overlays on that button (Ugly way of doing it but it works )
Make sure that if you are using PRI/BRI that you create at least 1-2 overflows and you cascade those DN's sequentially, this will avoid the caller getting a busy tone.
(PS) You should try to provide the associated ephone configuration to accompany the ephone-DN configuration, it helps with understanding how you set this up
Hope this helps..
Cheers,
David.
07-28-2011 10:20 AM
Hi David,
Thank you for the reply. I am still having many problems with this. Could you tell me if the extension 500 listed in your configuration example is meant to be associated with a shared number or with voicemail? Using 500 where you did, for me, makes it so no phones ring at all when the main number is called. Changing that to 600, which I have no set up as a shared number for 2 phones, allows both phones to ring on the first call; but if that call is answered, subsequent calls cause a call-waiting beep, but the other phone doesn't ring, and the call never goes to voicemail.
07-28-2011 10:39 AM
Also, here is my current config. As you can see I no longer have the blast group configured, these two phones are just trying to us a shared line
voice-port 0/3/0
trunk-group ALL_FXO
compand-type a-law
connection plar opx immediate 600
description Configured by CCA 4FXO-0/3/0-Custom-OP
caller-id enable
ephone-dn 155 octo-line
number 600 no-reg both
pickup-group 1
label Main Line - xxx-xxx-xxxx
description 600
name Front Deskone
call-forward noan 500 timeout 12
no huntstop
night-service bell
ephone 10
device-security-mode none
mac-address 0011.208E.xxxx
ephone-template 16
username "xxxxxx" password xxxxxx
type 7940
button 1:155
ephone 13
mac-address 000B.BE94.xxxx
ephone-template 16
username "xxxxxx2" password xxxxxx
type 7940
button 1:155
rule 1 /^6/ //
07-28-2011 12:24 PM
I'm reading cisco documentation here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html
And it says the following about shared lines:
Cisco Unified CME 7.1 and later versions support SIP shared lines to allow multiple phones to share a common directory number. All phones sharing the directory number can initiate and receive calls at the same time. Calls to the shared line ring simultaneously on all phones without active calls and any of these phones can answer the incoming calls. After a phone answers a call, the ringing stops on all phones and the call-waiting tone plays for other incoming calls to the connected phone.
In other words now that I've switched to shared lines the phones are acting as designed, which is useless to me. So it's not a shared line that I need. I guess I need to go back to the call blast group or hunt group and try to change the original behavior. I'd very much appreciate anybody's input on this who can answer my original question. To re-iterate, if one of the receptionists is on one of the phones on the front desk, the other phone still needs to ring when the main number is being called.
07-28-2011 03:26 PM
Hi Tamer,
I'm always willing to explore other avenues, not meaning to send you down a long windy road, but it was worth a shot to see if it resolved your problem
At a client I just did an install at, they have three Receptionists at the front counter, 1X SPA-525G2 with 2 Modules, and 2X SPA-508G's
To have this reception function correctly I created a reception blast group and put all three phones in there, further to that I tried turning off the call-waiting-beep on each of their DN's manually, and turns out it don't work I have no answer to that, this function did work, and I triled all the ways of doing it, but it does work when it is a direct to phone call from the outside world and an internal phone calling, NO beeps but activity on the screen.
Potentially a bug me thinks, and I am going to work more on this, sadly I have to cut back on doing testing during working hours before I get myself in a lot of trouble, so will try and schedule in some time to do it after hours and if it turns out to be a bug will log a case with support and report it.
Cheers,
David.
08-01-2011 07:15 AM
Please let me know if you find, or can think of, any solution to this issue. This is a huge problem. Right now if someone calls our front desk and the line is in use, it just rings, it never goes to voicemail. In your situation, David, does the voicemail pickup in that circumstance after a certain amount of rings? This seems like a very simple and standard thing for a phone system to do, and the fact that I can't get it to work on this system is really getting some people angry.
Should I try to open a case with support?
08-01-2011 03:03 PM
Hi Timer,
I have set the CFB timer to 10 seconds which then goes to the VM, this shall suffice for now.
And YES you should notify support, absolutely, I don't always practice what i preach and come to regret it later on, the sooner you have a case open the sooner you can get to resolving the problem, and if it is a bug the sooner the Dev team can start working on a resolution for it.
I would open a case on this, but I have about 8 cases now piling up waiting to be logged, I have dug myself a grave and I am just working out if I need to cremate myself to get it over and done with
Cheers,
David.
08-03-2011 12:40 PM
That actually works? Could you tell me how to set the Call-Forward Busy timer? I assume that's global but I can't figure out where it's set.
08-03-2011 10:52 PM
Hi Tamer,
Yes it does work, but there is more than one way of achieving this
If you are having troubles with setting this up I am more than happy to give you some remote assistance if you want and we can go through this using CCA and we can get this baby working the way you want it too
Just keep in mind of the time zones so I can make sure I am awake...
Cheers,
David.
08-03-2011 12:56 PM
Wouldn't you just have to add this to ephone-dn 10?
