Community Member
Display of Parked Call Extension
Is there a way to configure the parked call extension to stay on the phone display longer or until the next phone action?  I think our settings is about 5 seconds and sometimes people forget where the call was parked or forget to make a note of it.  We are using a UC560 with SPA504G phones.
1 REPLY
Re: Display of Parked Call Extension
You can't modify that, however you can tweak the reminders to make sure they know of the parked calls.
park-slot
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/command/reference/cme_p1ht.html#wp1106288
timeout seconds
(Optional) Sets the call-park reminder timeout in seconds.  Range: 0 to 65535. This reminder sends a 1-second ring to the IP phone  that parked the call and displays a message on the LCD panel of all  phones in the Cisco Unified CME system, indicating that a call is on  hold. By default, the reminder ring is sent only to the phone that  parked the call.
limit count
(Optional) Sets a limit on the number of reminder or retry timeouts.  Range: 1 to 65535.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
179
