Does the Live Record feature work with analog phones?
I have a Polycom conference phone that we would like to use the Live Record feature with and do not know if it is supported.  Is there a "hookflash" command summary available for analog devices?
Thanks for your assistance,
Kelly
Everyone's tags (4)
1 REPLY
Re: Does the Live Record feature work with analog phones?
You should be able to initiate a meet me conference to the Live Record extension using a FAC from an analog phone. You can change the FAC (and use a start code, for example) using this command:
UC500(config)#stcapp feature access-code
UC500(config-stcapp-fac)#?
STCAPP feature access-code configuration commands:
  call               Select call forward all feature
  default            Set a command to its defaults
  meetme-conference  Select meetme conference feature code
  no                 Negate a command or set its defaults
  pickup             Select pickup local group feature
  prefix             Select feature access code prefix
Remember that the FXS ports need to be in SCCP mode.
Marcos
3587
