Hi Yogi-B-Bear
Cyber Data products work really well with the UC-500 series, I have installed 1X Paging system and 1X Door stations (Without Striker).
However the issues sits squarely with the fact that in the current version of CCA, you have to still manually program the SIP settings, which as I understand it can be a bit of an issue and you may need to get SBS support involved, and that in itself is a huge HIT-Miss, both times I have called about doing this, the results were widely all over the place, I just ended up hanging up and doing it anyway (First in the LAB to test CCA sensitivity), they will either say you cannot do it, and if they say you can do it, they are not quite up there yet with programming the CLI
All decent Cyber Data products that work exceptionally well with the UC-500 series are SIP only, and if you want proper call tear downs and no locked ports/service then this is truly the way you need to go
The link you show will work with the UC and it will work well so long as you program the SIP info on the UC correctly, be prepared to hit some stubling blocks on the way, but hey it is a fun challenge.
Hope that helps.
Cheers,
David.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
