Community Member
e911
VA has passed e911 legislature. We have to implement it with any new buildings after July 1, 2009. Has anyone else had to implement this? If so, how did you go about it? We currently send the the number of the building and address but not the individual phone extensions within the building. Any suggestions?
Wushuspinner
Everyone's tags (3)
Re: e911
Hi Wushuspinner,
The users of IP phones in this part of the community typically use the SPA9000 Voice System which provides call-control for up to 16 IP phones so they may not run into this as much as others with larger systems.
Anyone else out there with some additional insight?
Patrick
Community Member
Re: e911
Thanks for the input. We are currently running centralized CM 6.0 with cisco 2800 routers at each building as their gateway. Each building has around 50 or more phones. Anyone out there have a similar situation?
Community Member
Re: e911
This community is for Small Business products. My advice is that you contact your pre-sales representative with Cisco so they can provide design guidelines pertaining to your solution.
Thanks for understanding,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Community Member
Re: e911
Here is a link to the NetPro forums your question would be better addressed on this forum
If you search for E911 you will find several posts that may address your question or you may post a question.
http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=5E6C083B804C2355F0F321A805C62D48.SJ4B?page=Unified_Communications_and_Video_discussion
Community Member
Re: e911
Here is a link to Cisco Emergency Responder which should meet your needs.
http://www.cisco.com/en/US/products/sw/voicesw/ps842/index.html
2835
