Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
error at upgrade uc520
Hi everyone,
we have a new uc520 and I tried to change the language follow the steps read here , but it can’t be done,
and now the uc520 cannot read the voice data and when I trying to reset to default factory settings it says:
“Current Factory default configuration and software package on this device are out of sync. …install the newer version of package…”
I have then new version in my PC, but when I tried to upgrade it said
"cannot retrieve CUE version information"
I found this thread  the same problem
https://www.myciscocommunity.com/thread/2376
At the end of the threat a guy wrote:
“the tac engineer found the problem..
the unity ip wasnt in the access list, so the cna couldnt read all the voice data
once he fixed that cna could read all voice data, and the upgrade worked as well”
How can we restore to the default factory status (as new) or what can i do.
Thanks a lot.
Everyone's tags (3)
Re: error at upgrade uc520
A quick way to reset to factory default is to use CLI:
1) Telnet to 192.168.10.1 and log in.
2) Type "enable" and enter enable password.
3) Do a "copy flash:UC520XXXX startup-config", where "UC520XXXX" is the default config file on your flash. You can hit the tab key to complete the file name.
4) Do a "reload"
5) After the UC500 comes up, try to upgrade again from CCA.
Let me know if this works for you.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
I did it, i copied the file and did a reload.
after reload i connected by CCA and i traied to upgrade but i said "Cannot retrieve CUE version information"
is there another way?
Thanks.
Can you post the CCA logs? Just press F2 while trying to do the upgrade.
Marcos
this is the Log
++: DEBUG:  : Current CUE transport timeout =5000
++: DEBUG:  : Current CUE deliver timeout =600
++: DEBUG:  : Session clear command sent
++: DEBUG:  : Session command = service-module Integrated-Service-Engine 0/0 session
++: DEBUG:  : Logged into CUE.
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at com.cisco.nm.lib.cmdsvc.telnet.TelnetTransport.read(TelnetTransport.java:483)
at com.cisco.nm.lib.cmdsvc.TelnetSession.rawRead(TelnetSession.java:118)
at com.cisco.nm.lib.cmdsvc.Session.read(Session.java:318)
at com.cisco.nm.lib.cmdsvc.Session.tune(Session.java:796)
at com.cisco.nm.lib.cmdsvc.Session.tune(Session.java:779)
at com.cisco.cpnm.frmwrk.net.cmdsvc.CUEPlatform2.learnCuePrompt(CUEPlatform2.java:84)
at com.cisco.cpnm.frmwrk.net.cmdsvc.CUEPlatform2.bladeSession(CUEPlatform2.java:286)
at com.cisco.nm.lib.cmdsvc.OpEnterBladeSession.invoke(OpEnterBladeSession.java:53)
at com.cisco.nm.lib.cmdsvc.SessionContext.invoke(SessionContext.java:296)
at com.cisco.nm.lib.cmdsvc.Engine.process(Engine.java:57)
at com.cisco.nm.lib.cmdsvc.LocalProxy.process(LocalProxy.java:22)
at com.cisco.nm.lib.cmdsvc.CmdSvc.enterBladeSession(CmdSvc.java:252)
at com.cisco.cpnm.frmwrk.net.cmdsvc.RecordableCmdSvc.enterBladeSession(RecordableCmdSvc.java:46)
at com.cisco.nm.lib.cmdsvc.CmdSvc.enterBladeSession(CmdSvc.java:219)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getCUECmdSvc(McebuVoicemailDataImpl.java:222)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.initiateCUEInfo2(McebuVoicemailDataImpl.java:295)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getCUECLIResMap(McebuVoicemailDataImpl.java:156)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getCUEConfigs(McebuVoicemailDataImpl.java:3796)
at com.cisco.cpnm.features.mcebu.defn.cue.CueDevice.retrieveCueConfig(CueDevice.java:266)
at com.cisco.cpnm.features.mcebu.defn.cue.CueDevice.initGetConfig(CueDevice.java:223)
at com.cisco.cpnm.features.mcebu.defn.cue.CueDevice.setNE(CueDevice.java:281)
at com.cisco.cpnm.features.mcebu.defn.cue.CueDeviceManager.getDevice(CueDeviceManager.java:40)
at com.cisco.cpnm.features.mcebu.defn.cue.CueDeviceManager.setNE(CueDeviceManager.java:78)
at com.cisco.cpnm.frmwrk.net.ne.NetworkEntity.initInstance(NetworkEntity.java:335)
at com.cisco.cpnm.frmwrk.net.ne.NetworkEntity.getInstance(NetworkEntity.java:231)
at com.cisco.cpnm.legacy.networkdata.CommonSwitch.getInstance(CommonSwitch.java:1707)
at com.cisco.cpnm.frmwrk.net.ne.NetworkEntity.getInstance(NetworkEntity.java:277)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getSystemInfoManagementIf(McebuVoicemailDataImpl.java:4026)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getCueGlobalVersion(McebuVoicemailDataImpl.java:3602)
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuCueSoftwareData.getCueGlobalVersion(McebuCueSoftwareData.java:960)
at com.cisco.cpnm.features.mcebu.cuc500.swupgrade.CUC500SoftwareUpgradeSettingsTask.updateDeviceFromMirror(CUC500SoftwareUpgradeSettingsTask.java:109)
at com.cisco.cpnm.frmwrk.gen.wd.WDContainer.updateDeviceFromMirror(WDContainer.java:704)
at com.cisco.cpnm.frmwrk.gen.wd.WDTask$SetConfigRunnable.run(WDTask.java:1258)
at java.lang.Thread.run(Unknown Source)
++: DEBUG:  : Exception: java.net.SocketTimeoutException: Read timed out
++: DEBUG:  : Learned CUE Prompt = null
at com.cisco.cpnm.frmwrk.net.cmdsvc.CUEPlatform2.setPrivExecMode(CUEPlatform2.java:210)
at com.cisco.cpnm.frmwrk.net.cmdsvc.CUEPlatform2.bladeSession(CUEPlatform2.java:292)
com.cisco.nm.lib.cmdsvc.CmdSvcException: java.net.SocketTimeoutException: Read timed out
at com.cisco.nm.lib.cmdsvc.Session.tune(Session.java:869)
7903.734 com.cisco.nm.lib.cmdsvc.OpEnterBladeSession.invoke(OpEnterBladeSession.java:64) [ERROR] WARNING: OpEnterBladeSession: old prompt 'UC520#' and new prompt 'UC520#' are identical
at com.cisco.nm.lib.cmdsvc.Session.send(Session.java:245)
at com.cisco.nm.lib.cmdsvc.Session.send(Session.java:131)
at com.cisco.nm.lib.cmdsvc.Platform.testUniqueCmdResponse(Platform.java:175)
at com.cisco.nm.lib.cmdsvc.LinuxPlatform.isCurrentPlatform(LinuxPlatform.java:58)
at com.cisco.nm.lib.cmdsvc.Platform.discover(Platform.java:100)
at com.cisco.nm.lib.cmdsvc.OpEnterBladeSession.invoke(OpEnterBladeSession.java:66)
at com.cisco.nm.lib.cmdsvc.Session.send(Session.java:306)
++: DEBUG:  : Clear CUE CLI res Map
java.lang.NullPointerException
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getCUEConfigs(McebuVoicemailDataImpl.java:3797)
2009.05.21-03:10:13-MST DEBUG Device: get running config
++: DEBUG:  : AuthGrp@1d0e17a: getAuthCreds() called for: telnet://192.168.10.1:23; realm: null
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getSystemInfoManagementIf(McebuVoicemailDataImpl.java:4028)
7940.734 com.cisco.nm.lib.cmdsvc.OpEnterBladeSession.invoke(OpEnterBladeSession.java:64) [ERROR] WARNING: OpEnterBladeSession: old prompt 'UC520#' and new prompt 'UC520#' are identical
at com.cisco.cpnm.features.mcebu.defn.voicemail.McebuVoicemailDataImpl.getSystemInfoManagementIf(McebuVoicemailDataImpl.java:4029)
using console, is there a way to upgrade or replace system files?
Jonatan,
You could use tftp, but it´s alot of commands since you manually have to change your config as well
Eivind
Thanks Eivind
At this point the unity doesn't work, it can not read Voice configuration in CCA and it can not be upgraded, so what can I do to get the unity worked again.
Jonatan,
Are you able to reach Unity from CLI???
Use the command "service-module integrated service-engine 0/0 session" if I´m not completly mistaken... Use TAB to get help on the commands...
Eivind
I wrote the command, but nothing happen.
UC520#service-module Integrated-service-engine 0/0 session
Trying 10.1.10.2, 2002 ... Open
Any idea?
try to press "enter" key
Eivind
i pressed Enter many times but nothing happen so i did a reload and after it I check the service using "status":
User Access Verification
Username: cisco
Password:
UC520#enable
UC520#service-module Integrated-service-engine 0/0 status
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is waiting for registration message
Service Module status is not available
UC520#
It does not open 10.1.10.1 at browser but 10.1.0.2 does so  i copied the result of  Show Tech Support and attach the file in this thread.
Jonatan,
I guess you waited a couple of minutes after the reload before you issued the command??? It takes some time before the CUE is finished loading. Anyways, this seems like a case for TAC, or maybe one of the Cisco guys in the forum...
FYI
I issued the same command and got:
uc520#service-module integrated-Service-Engine 0/0 status
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 3.2.1
CUE running on UC500
Eivind
UPDATE:
Are you using console, telnet or SSH???
I use console to write the command:
service-module integrated-Service-Engine 0/0 session
and the same time i use telnet  to:
You are right Eivind, after a couple of minutes it start to answer in console i attach the result,
now in telnet with  "service-module integrated-Service-Engine 0/0 status"  command it says
UC520#service-module integrated-service-engine 0/0 status
Service Module is failed
If you type *** before the CUE boots, and try to format the CUE and reinstall with a new version
output from the engine.txt attached:
___________________________________________
Resetting devices ....Done.
mac address for internal ethernet 00:1b:a0:2b:45:9e
Please enter '***' to change boot configuration:
ServicesEngine Bootloader Version : 1.0.3
Or maybe send marcos@cisco a message to see if has a better option....
If you decide/manage to upgrade CUE with CLI, have patience, this takes about 40 minutes or so.. also then you can upgrade the IOS using TFTP and you are up and ready with a new version (hopefully) within a couple of hours of work.
Eivind
...If you type *** before the CUE boots, and try to format the CUE and reinstall with a new version...
how can i format and reinstall CUE?
is there a page with commands?
...havee patience, this takes about 40 minutes...
it doesnt matter the time or the count of commands i can do it but i dont know how.
thanks
Jonatan,
I´ve found this document for you, make sure you completly understand every step before you start
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/boothelp.html
The latest software packages can be downloaded from:
https://supportforums.cisco.com/docs/DOC-9829
Download the complete ZIP file and extract the unity files you need. You should upgrade the IOS before CUE, if we are follow the same procedure as CCA.
DON NOT start this process if you are uncertain of any steps in the guide/process.
Follow Skyler´s recommondations first, that´s my best tip for now...
Eivind
Can you try out the following command?  service-module integrated-service-engine 0/0 reload  You should see output as follows:
UC500#service-module integrated-Service-Engine 0/0 reload
Do you want to proceed with reload?[confirm]
Trying to reload Service Module Integrated-Service-Engine0/0.
Then try another status check and see if the output matches this:
UC500#service-module integrated-Service-Engine 0/0 status
Service Module is trying to recover from reset/shutdown
Yes i tried the command
and After a long while it says the same
Ok then, try using "reset" instead of "reload", this will hardware reset the module.  Wait just a minute (not a long while) and try to session in again.
i use the reset command and after a minute
i use the session command and the result was the same it stop as follow:
                Welcome to Cisco Service Engine
Wed May 20 17:30:00 PDT 2009
********** rc.aesop ****************
rsrc_file:/etc/freddo_rsrc_file
Populating resource values from /etc/freddo_rsrc_file
rsrc_file:/etc/default_rsrc_file
Populating resource values from /etc/default_rsrc_file
rsrc_file:/etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
entry : change cli_server:standalone:int32:0
rsrc_file:/etc/products/cue/freddo_rsrc_file
Populating resource values from /etc/products/cue/freddo_rsrc_file
lcp: .3 COMPLETED
lcs: .3 STARTED
start_next_phase .3
main sub_phase:  3
nsp phase_file:  /bin/installer_phase_steps
at the same time by telnet it says
and after a couple minutes it says
So you are saying that you ARE able to session into CUE directly following a reload command?  But when you do it displays what you posted and then when it reaches the lines
lcp: .3 COMPLETED
lcs: .3 STARTED
start_next_phase .3
main sub_phase:  3
it kicks you back out.  Am I correct?  If this is the case then perhaps CUE did not install successfully last time you upgraded.  Elvind's suggestion seems to be the correct course of action, but given the difficulty of manually installing CUE through CLI I highly recommend opening a TAC case so that someone can guide you through the process.  If you choose to follow the steps outlined in the document elvind linked to by yourself, please post your questions here.
Thank everyone,
I reinstall CUE manually using my Pc as TFTP server and using boot helper, it take me a long time cause i was using a wrong config, but i found the document attached and i used this configuration and it works
IP Address: 10.1.10.1
Subnet Mask: 255.255.255.252
TFTP Server: 192.168.10.11
Gateway: 10.1.10.2
Default Helper File: cue-vm-installer-k9.ise.7.0.3
Ethernet interface: Internal
Default Boot: Disk
Now CUE its running, i update the CCA to 2.0 and it looks great
So i hope it works everthing fine,
Thanks to everbody again !!!!
Jonatan,
This document saved me getting the TAC involved for a project that I'm currently working on.  The CUE module hung when upgrading to 8.0.0 via CCA 2.2 and when I restarted the unit, CUE was broken.  Thanks for posting this, I saved a copy of the document.
Seth
Thanks very much!!!!
Hi, I'm hijacking the thread with a similar problem.
Unboxed a brand new UC520 today, started with updating IOS to latest version and downloaded CCA 2.0 to get all the nice features for tomorrows install.
The problem started when I tried to upgrade the CUE using the CCA, after selecting the right files and language. (At this point there's only 12 MB left on the flash card.)
After I hit upgrade it shows "Backing up CUE" or something similar. Four minutes in it failes. I deleted the old IOS to make more room to make sure that the lack of space was'nt the error. I tried again and got the same error. Going to try with a 1 GB card if it makes a difference.
Am I doing something wrong? And why is it so difficult to update this box?
Thanks!
Can you try to upgrade the CUE module and once you are done then try the localization?
Marcos
Thanks for the reply!
Nothing worked, so I formated a 1 gb and did a fresh install with  UC520-7.0.3.zip then it was a walk in the park.
Don't really understand the choice of 128 mb cards since they cause so much headache.
Hi Junghage,
you can see if CUE is running using telnet or console:
and if its enabled you can try upgrade again using CCA upgrading only CUE first, if not enabled you can reinstalling CUE manually but it is not easy.
18755
