European FSK Caller ID
stylecomltd
I have Linksys SPA400 and can't get Caller ID on incomming calls. Waiting for firmware that will fix this over 2 years.
I use this adapter on 2 installs: one with SPA9000 and one with Asterisk. Same problem with both.
I am from Bulgaria. Telecom operator Vivacom ( formerly BTC ).
With SPA3102 Caller ID is working fine. Settings are ETSI FSK - bell 202 and FXO Port Impedance 600
Tried all suggestions in other posts with no success.
Also I find a document from my provider that describes specifications for end-user devices:
Specification ETSI ETS 300 6593 FSK
Timeparameters:
500 ms ≤ T5 ≤ 2000 ms
T6 ≥ 200 ms
T 9 = 0 ms to 150 ms
T 10 = 0 ms to 150 ms
T 11 = 40 ms to 55 ms
T 12 = 55 ms to 200 ms
T 13 = 40 ms то 120 ms
T 14 = 160 ms ± 5 ms
Can you give me some advise how to get CLIP from my lines?
24 Replies 24
I am facing similar problems with PSTN lines in Lebanon. I tried the localization settings as follows:
Lebanon 0 270+(750||150nF) 3.5 10 3 Enable North America
no success at all. I tried lot of settings and I upgraded to the latest beta firmware. Any suggestions to solve this problem ? Usually here we FSK settings with caller id after first ring. how can i apply it?
Dear Naim;
If you have FSK with PR, then please try European FSK.
Alberto
idiamanti
For God's shake!!!!!!!!!!!
We are waiting for an answer (what ever will be), from Cisco.
We have disappointed customers and we don't know what to tell them.
Dear Sir;
I'm trying to help you as much as possible with this resolution, which is not easy based on the fact that threads are including multiple countries and multiple type of lines. This is hard to replicate as may not be able to see the issue you are seeing
I suggest that if you have urgency to solve the issue, please contact the Small Business Support Center. http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Regards;
Alberto
Hi Alberto.
Any news from your Engineering Team?
When we can expect something?
John
Dear Sir;
Checking. Will provide you an update as soon as I get a response
Alberto
Dear Alberto,
After one and a half month, i'm comming back to ask you to contact with your engineers and remind them the subject problem.
Is there any progress?
And one more info, with SPA-3102, there isn't such a problem.
John
idiamanti
Dear Alberto,
is it possible to ask your engineers, if they have examined the proposal that we sent with our first message (14 April)?
John
Four years you can't fix this CallerID problem.
Please tell us it will be solution or not.
If not I'll get the all SPA400 direction to the trash.
Have you try to change the Ring Validation Time under Voice-Line menu?
Try to change the default value to 100 ms.
Regards.
