Community Member
External Aerial for Uc500
Hello all
Have a customer who requires en external aerial for their UC500.  System has to sit in a solid concrete room.  Can anyone suggest an appropriate aerial that I can attach to the system to enable the wireless option to be usable on the system
1 REPLY
Re: External Aerial for Uc500
Hi Damien,
There is a pretty good guide at the following location;
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
I'm guessing from your brief description you wish to extend the internal wireless AP found inside the UC5X0W series.
You would need a TNC patch cable and appropriate antenna  that worked in the 2.4Ghz frequency range.
eg.  Maybe 20' patch cable p/n  AIR-CAB020LL-R and maybe with a p/n AIR-ANT2485P-R patch antenna.
But, please choose the appropriate cable length and appropriate antenna to meet your customers needs.
regards Dave
913
