External Conference calls failing
Installed a UC560 at a customer site with a SIP connection to a COX Edgewater. Incoming and outgoing calls are working but having trouble with conference calls. Conference calls work internally but when you try to conference in an external caller the call fails.
Any help would be greatly appreicated.
1 ACCEPTED SOLUTION
Could you please share the output of "show dspfarm profile".
Also please double check if the codec is g711ulaw. Debug ccsip messages and debug ccsip media, and debug voip ccapi inout should tell you if the codec is 711ulaw.
You may have setup g711ulaw but something may have changed in the config.
Best regards,
Alex
Hello Tim,
You should check if you have the conference set with different codecs if you are using g729 for the sip trunk.
HTH,
Alex
*Please rate helpful posts
Hi Alex,
g711u is being used on the SIP trunk.
Hi Tim,
What is the type of the conference ad-hoc(you call the other participants) or meet me(participant calls a specific number) that you are trying to get working?
If you are using CCA just enable the hardware conferencing.
how many participants you are trying to add to the conference and wha is the type of the phone?
Best regards,
Alex
The type of conference is ad-hoc. Calls fail when trying to add one external participant. The type of phones are SPA514G.
sccp local Vlan90
sccp ccm 10.3.10.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum conference-participants 32
maximum sessions 2
associate application SCCP
Best regards,
Alex
What exactly do you mean the call "fails"; re-order tone, doesn't ring out, ...?
Can you provide the output of "debug ccsip mess" while attempting a conference?
Codec issue, everything is good now. Thanks
299
