fax machines on uc560 with PRI and FXS ports?
During a quote meeting today, we were asked about attaching a fax machine on the uc560 via FXS port. My experience has been that using fax machines on FXS ports off a t1 can be hit or miss. I was informed by the potential customer that when using a PRI, if there's no conversion on the PBX off the PRI into a codec and then back to the FXS port where the fax machine is, the fax machine works 100% of the time. 1) Is that the case with a PRI/FXS-FaxMachine combo and 2) if using a PRI on the uc560 with a FXS port with attached fax machine, is there any signal conversion into a codec, or is signal relayed straight from the PRI to the FXS? (thus ensuring that Faxing to FXS attached FaxMachine over PRI to will be 100% successful?)
Re: fax machines on uc560 with PRI and FXS ports?
As long as the faxes are coming in via PRI then you’ll be fine – and quite easy to configure with CCA.
Hi Jeff,
In my experience is has always been a hit and miss situation, with ISDN and PRI the misses still happened but not as often, although in recent SW pack releases I believe this to have improved maybe???
It has been a long held practice to just keep them separate and let them run of their own line, however I am now facing situations where clients would like that level of integration, the problem is I do not have a lab environment with a PRI setup to test this and see how it fairs up now.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
573
