Community Member
FXS Port MAC Addresses
I need one of the FXS ports to be an ephone.  That should be accomplished by changing the analog port to a user phone but it is not working.  Where do the MAC addresses come from that are used for the FXS ports where I could manually put it back in?
1 ACCEPTED SOLUTION
VIP Purple
Re: FXS Port MAC Addresses
Do you have STCAPP configured for the FXS port? If so, you can issue the command "show stcapp device summary". This will show you the MAC address of each SCCP controlled port.
Hope this helps.
Brandon
VIP Purple
Hope this helps.
Brandon
Community Member
Thanks for the help.  Once I added the stcapp service, it added the ephone.
862
