Community Member
Half Second Delay on Answer
When anyone makes a call from one extension to another there is a short delay before the called party can be heard. This only occurs on internal calls and incoming calls from FXO ports are not delayed. I am running the latest version of firmware on the UC320 my switch is a ESW 520-24P and my phones are SPA504G. Is there any fix for this issue?
1 ACCEPTED SOLUTION
Bronze
Hi Adrian,
Please install Disable_RTCP.pmf at Status->Devices->Alter PMFs in configure utility. Please apply the configure afterwards.
You can download this pmf at https://supportforums.cisco.com/docs/DOC-16301
Best regards,
Wendy Yang
Bronze
Hi Adrian,
Best regards,
Wendy Yang
Community Member
Thanks Wendy,
This has resolved the delay issue.
ap
333
