Having issues with Quotes in the formating on my 79xx phones
Please take a look at the attached jpg.  All of my 79xx phones have these quotes at the end of alot of the menus.  Have tried creating the cnf files and resetting the cnf files in CCA but it keeps coming up.  Any ideas?
Everyone's tags (3)
Hi Thomas,
I have a 7970 here that had the same problem, I did a factory reset on it and let it do its thing after the reboot and the quotes left.
But I also changed the locale from US ENGLISH to UK ENGLISH as well (That was accidental was only supposed to do voice mail).
But the factory reset did the trick for me, haven't seen it on other 7900 series only on the 7970.
Give it a shot it might work for you as well
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I actually fixed the issue when I fixed an issue with my 7937 Conference Station phones.  The conference station phones would not register but I found a fix by adding US English in the telephony-service as the locale, after a reset of the system, the 7937's registered correctly and the quotes were gone from all of the other phones.
Got lucky I guess.
Glad its resolved
371
