Community Member
Help needed with outgoing calls on UK PRI interface
I have recently just installed a UC520 with the T1/E1 card for my customers ISDN30 line. we can receive incoming calls perfectly OK but when we try to dial out we get a dial tone but then we get a message back from BT saying the number is not recognised. where am I going wrong.
I have installed another UC520 on another site although that one is only using the FXO ports for outgoing calls, this system works perfectly.
any pointers where I need to look would be greatly appreciated.
Chris
Community Member
Re: Help needed with outgoing calls on UK PRI interface
Check and match sure your outgoing dial plans are set for UK dialing, it defaults to Argentina.
Carson
Community Member
Thank you for your reply Carson, I sorted the issue out myself.
I changed the switch type to Net5 instead of 5ESS which BT told me it should be set to. Once it was set to Net5 incoming and outgoing calls worked perfectly.
883
