03-03-2010 05:43 AM - edited 03-21-2019 02:15 AM
<Idle_Key_List ua="na">resume|1;psk1|2;dir|3;redial;lcr</Idle_Key_List>
Identical config works on SPA525 and amazingly it also works on a 502G
03-04-2010 05:35 PM
Compare the 502 with your 504 and see if on the 502 that you have SIP enable to Yes or Linksys Key System to yes and the 504 has no on both. I know that lcr is affected this way for the idle softkey.
04-12-2010 03:18 AM
Both phones now don't display resume
works fine on 525 running 7.4.4
on 504 you can get the call back by pressing the line button
on 502 you are screwed
sounds like the same problem as -dnd no appearing with
Re: Device Feature Key Syncronization does not work on 502/4G 7.4.4
04-12-2010 09:20 AM
Ok, we are looking at this from the other link that you gave. Working with Alberto and QA at this time, please respond to Alberto in the other link as we will look at this from the other link. Thanks.
04-28-2010 06:15 AM
We desperately need a solution to this. (No Button)
Nothing clever - this is VoIP 101
04-30-2010 10:40 AM
I've emailed Alberto about having him reply to your post https://www.myciscocommunity.com/message/43329. Thank you.
